If you had a grid of superconductive wires that was isolated from the rest of the world, you could have a perfect bonding grid.
However, the real world is much more complicated. If you have a voltage source and a destination that is at a different potential, you will have current flow.
Any time that you have current flow and any resistance, you will generate a voltage differential
So, if you have an underground wire leaking electricity, and it gets to something on the bonding grid, current is going to flow through the grid to wherever the voltage is different.
There can be multiple connections between the ground and the bonding grid. Such as at the pump, light niche etc.
Because everything on the bonding grid has different conductivity, you will have some voltage gradients.
You have water, concrete, copper, steel etc.
So, you will never have a perfect bonding grid with zero potential difference between different points when you have a voltage source and a destination that supports current flow.
The grid should reduce the voltage differential to a safe level assuming the grid is in good condition and the current flow is not too high.
So, you can get noticable nuisance voltage, but hopefully, it won't be dangerous.
Note: When you have a wire powering a load, you get a voltage drop. So, the voltage at the breaker might be exactly 240 volts, but the voltage at the pump will be lower, maybe 235 volts.
The voltage drop depends on the current (amps) and the resistance (impedance) of the wiring. So, even though the two points are connected by copper wire, they are not at the same voltage. If the pump is off (zero amps) there is no voltage differential.
