And for the liner if you have cantilever bricks you would need to change the liner track to use aluminum coping track combo, which would require dropping the liner.
What does your electrician say?
Did you ever get a frequency test?
True on electricians BUT between them, the power company and inspector should they not be able to track to where this shock is coming from while they are on location ?
You are assuming that a bonding grid works perfectly in practice as theory says it should. Electricity is funny and follows its own paths of least resistance. Hard to say any bonding grid is perfect as it ages. Your bonding grid may be ok and is keeping you from getting more shocks then what you feel.
I would look for the source of the shocks. Once you understand where they are coming from you may have a better idea if your bonding grid should have prevented the shocks.
Most people’s bonding grids are theoretical and have never been tested. I am sure many don’t work adequately.
Not trying to be mean lol, but sense May of 2014 i think it is about time to get that guy out lol. You can test your bond like this. You are sitting on , standing on, touching an object. You touch another object. You feel a buzz. THOSE 2 items are then NOT bonded. ( bonded = objects tied together via a wire ) The connections have to be clean and welded / soldered to stand up over time. If not they will trickle small amount of voltage to flow. The trick is all about being on and staying on the same potential. To do this the objects have to be wired together. Just a side note and not your problem. If you are insulated from ground you can touch the hot side of the power in your house, you can then touch the hot side again somewhere else. Touch the ground side and your going to jump lol. Touch something that does not have a good ground and you will feel a slight buzz. Doing this you are connecting yourself between two potentials. Staying on the same and no issues.
Sooooo, where you get your buzz, get those 2 items tied together, if you say they are, sorry , wrong answer, they are not.
they may have meant welded or soldered to the grid attachment point....maybe.
I have never seen a welded or soldered joint on a bonding grid. I've ripped out many pool decks and prepped a few including my own. If rebar is used and wire tied then bond lugged it will hold up. The rebar rusts inside the concrete but fuses together and so does the bond lugs. I am not a fan of rebar in a pool deck. Fiber mesh does a much better job and the prep is key to the base. I haven't looked back in this thread but has the obvious taken place line disconnect pool light and the feed to pool equipment? And yes you should unhook the ground rod you may have current down the house ground thats backfeeding into the bond grid. The obvious stuff is a quick easy set of elimination steps and should be done in one fell swoop then a pull of the meter which is also simple. Basically process of elimination.
Did you try testing the frequency?
Are you testing voltage on ac and dc?
Did you try testing ac and dc current?
Check all of these things with one lead on the bond wire and the other lead on the ground rod.
I just got back in from removing the bond wire from the ground rod I found. Now after doing this, my wife no longer feels the shock.
But if I stick one lead of my meter in the dirt outside the pad and the other lead in the water, I get a voltage reading of 1.1. If I turn the meter to ohms (digital meter) and stick one probe in the water and one on a ladder leg, I get a reading of 10-12. Am I just not doing the readings right? I ask this because I just went next door to my neighbor’s pool and they have wire mesh, rebar, and no shock, and all of the readings I did in my pool are the same in their pool. So now I’m confused..
