Hi Guys! This is my first post.
We have a 13.5K gallon pool (just over 1 year old). Only 2 users of the pool.
My PH has always been high. Have been having problems getting the pool crystal clear, so had my spouse take a water sample to Leslie's. I tested the same sample with my ColorQ Pro 7 and got the following:
FCL - 1.27 (Leslie's came back about the same)
TCL - 1.27 (Leslie's came back about the same)
PH - 8.1 (Leslie's came back about the same)
ALY - 114 (Leslie's came back 70!) Haven't a clue why their result is much lower.
CH - 114 (Leslie's came back 459!!!) Huge difference in the result.
CYA - 49 (Leslie's came back 61).
Phosphates - I did not test...Leslie's tested at 1961.
Leslie's said to do the following:
- Add 5# of Alcalinity Up
- Add 39 ounces of muriatic acid
- Add 32 ounces of liquid chlorine
- Add 1 gallon, 18 ounces of PhosFree (added 48 ounces on Saturday...cleaned my filers today and added another 48 ounces).
PH/ALY Issue -- I'm pretty much a novice, but adding muriatic acid to reduce PH and adding Alkalinity UP to increase ALY seems counterproductive...doesn't muriatic acid reduce both? What can I do to reduce PH, but not reduce ALY?
Chlorine -- Because of high CYA levels, I have quit using the 3" chlorine tablets in the feeder tube (CYA had been as high as 140...kept draining pool until I got under 50). Now use only powdered shock (with no CYA) and liquid chlorine. I add chlorine several X per week and my FCL/TCL still tends to be low. Any thoughts on why the chlorine level stays so low?
Thank you in advance for any guidance you can provide me!
