Marla it sounds like you are on the cusp of a contract!!! Will your husband sign at the lunch mtg?
Thanks Umm! The PB does plumb them separate, but I will ask about a control for them. What is the venturi effect?
I never knew to ask about this. What if my PB does not plumb ours separate???
You probably want to ask them if they do and if they don't can they. They might charge you for some extra plumbing and a valve. I think it really helps at least I am seeing with mine already. I can put more focus on the main drain when we are scrubbing to pull the dirt out of the pool but later switch more strength to the skimmers to try to get all the leaves before they sink to the bottom.
Umm thanks for the link! I have just emailed the PB to see if these are what they use. Are they normally considered an upgrade?
Thanks Casey! Getting closer!
