Anthony, sorry it took so long to respond. Yes, I do have a solid cover. I have never opened to a swamp, but I always prepare myself mentally for it, because I'm sure it will happen. Having TFP experts ready to help blunts the panic a lot!
In the past, when closing, I never finalized the close (heavy dose of Oxidizer, Sanitizer, and Baquacil Algaecide) until the water was 55-60 degrees for about a week. Algae can't grow at those temps. Then I did a very thorough vacuuming job, quickly lowered the water to a few inches below the skimmer, and immediately placed the cover on. When snow accumulates on top, I shovel as much as I can reach as soon after the snowfall (PLASTIC shovel!) as possible. You never get it all, but keeps excessive weight from pulling on the top of the pool, a problem you won't have. You get worms, etc. instead. Sorry. There's no free lunch, right? During the winter, give away, sell, or return everything Baquacil. The high cost of replacing it will prevent you from changing your mind.
When Spring arrives and everything on top of my cover is melted and mixed with rain, I use my pool net to catch as much accumulated sediment as I can. Then I use a small utility pump with a hairnet over the inlet (you can never have enough hairnets!) with an attached piece of garden hose (with another hairnet rubber- banded over the end of the hose) to put this free water back into the pool. I do this each time I get a decent accumulation of water on top, until my pool is full. Overfill it a little bit, and your initial vacuuming can be sent directly to waste (sand.) Not sure how you do it with DE, but you get the idea. Then pour in the chlorine, set up a chair by the pool, and let the adventure begin. I used 10% chlorine, which I purchased online from True Value Hardware @ $4.00 a gallon. It was shipped to my local store; no shipping costs. I just had to go pick it up.
As we talked earlier, our pools are similar in volume and mine required 34 gallons to complete. I noted you also used the Baquacil CDX, which I did not. That may make a difference, I'm not sure. Over the Winter, get your test kit acquired, and learn how Pool Math works. It will become your best friend. I over-tested in the beginning until I began to see that most of my numbers were nearly the same for weeks at a time, with only insignificant changes. I now only test for chlorine and pH daily. PH hardly ever changes; I need to add chlorine daily. I test for TA, CH, and CYA every week-and-a-half to two weeks. I was told to expect to use about a half-gallon a day of chlorine for my size pool. On days when the pool is uncovered all day and in use for half of it, I need to add about a quart of chlorine. Covered and no use--about 15 oz. At $4.00 a gallon, that equates to either $1.00 or $.50 a day. And don't forget, that is both my oxidizer and sanitizer. Also, I have used no algaecide, clarifier, flocculant, etc. all year. I can only imagine how much those numbers must shock you- they still shock me. But it's true, I have added nothing but chlorine and around $2.50 worth of 20 Mule Team Borax (pH-Up) since my initial set-up was finished. I occasionally go into the basement and re-count my used chlorine jugs just to make sure I'm not dreaming! My pool has never been cleaner nor more sparkling. No red eyes, green hair, chemical smell, or anything else us Baquacil-er's were told about chlorine.
To close this year, my first with chlorine, when the water temp is right, I expect to do a SLAM, stabilize everything, then add Polyquat 60 algaecide. I am currently reading up here on TFP to finalize my plan.
Let me know if I can be of any help; if you need any encouragement, etc. Us old guys have to stick together, LOL. Nearly every bit of experience I have shared is a result of using info gleaned from this site. I had so much help from the members on this site when doing my conversion. I am by no means an expert, but there are MANY on here who are, and they can't wait to help you.
