- Mar 5, 2020
- 3,221
- Plaster
- Astral Viron V35
That's no good news, Anthony. Get some rest, and I hope you'll get better soon, and that next summer will indeed be kinder to you.
Great idea Guzz !! Once the government bans them he can sell his hardly used pump for DOUBLE what he paid for it. Nobody cares until big brother says they can’t. Then they want to soooooooo bad. Lol.California has already gone to require variable speed pump motors.. I'm not sure where PA is on that yet. Its my understanding that requirement goes nationwide next year anyway.
Yes. All of the regents need replacing around 2 years. The ones you are currently still using have probably been replaced sooner than the ones that you didn’t need. Unless you bought the whole kit new each time. Then they are the same age and still good.
If you've gotten them from Taylor all the bottles should have expiration dates on them. At least all the bottles in my K2006 did.I just replace reagents as they get low. Usually order right from Taylor. The chlorine reagents, obviously, I've not used at all. Thanks for mentioning it. Another item to add to my list - might as well wait till closer to spring to get new ones (unless I still decide to drain and do this before closing yet- as I dither over this the more weeks go by, the less advantageous it almost appears).
Anthony, that diagnosis sucks. You don't need more to deal with. Now the pump! I admire your stick-to-it no-matter-what attitude. Keep your head up; things HAVE to begin to go your way. You're waaaay overdue!
Wishin' you all the best, man! Hang in there.![]()
Without knowing any details on this proposed ban, I would imagine it is like most bans. Not a ban on using it. Just a ban on the commercial sale of it. So you could sell your single speed pump, but a retailer couldn't sell one. This is how it usually goes. Cars get stricter emissions requirements, only applies to new vehicles. Existing ones only have to meet emmission for the year they were made. Incandescent bulbs were banned, but you could buy remaining stock and use them.Yeah..but..who will want it if not allowed to use it? This sort of thing is bit ridiculous from the standpoint of not being able to monitor if anyone bothers to run their VS pump at lower speeds anyway. Granted that they take less power overall than single speed, but still. just another way of the government sticking it to the pool customer and industry.
I've heard this, and it doesn't seem right to me. At least, running a VS pump at full speed. Same size pump moving same amount of water should equal same amount of power. Most motors are already 90% efficient or so, so there's not too much room there. I suppose you might get a % or two better, but the vast majority of the savings is being able to run the pump at a lower speed, since power and flow rate aren't linear.Granted that they take less power overall than single speed
Correct. Running my 3Hp pump wide open draws 2700+ watts. It’s a beast. But 1200 Rpms which is enough for skimming and the SWG is 115 ish watts.I've heard this, and it doesn't seem right to me. At least, running a VS pump at full speed
Wow. My Intex is rated for 4 A, which would be 480 W. And if I had to guess, probably moving similar or even more water (thanks to lower pressure drop of your larger plumbing and bigger filters compared to mine).Correct. Running my 3Hp pump wide open draws 2700+ watts. It’s a beast. But 1200 Rpms which is enough for skimming and the SWG is 115 ish watts.
I don’t know how people deal with it. I go to customers homes and I can tell from the driveway that the neighbors pump is running a whole yard away. I can only imagine hearing it from their own backyard every day. Mine is 15 ft from the hangout area and nobody has ever heard it.that background humming in the back yard is finally gone, and I'm sure my neighbours are very grateful, too
