- Nov 11, 2020
- 172
- Plaster
- Pentair Intellichlor IC-40
I figured I’d throw a few of my questions all under one post instead of multiple. Thanks for the help in advance!
1. To my understanding, I should face all of my 5 return jets clockwise to create circular flow toward my skimmers which are on opposite sides of my rectangular pool. Should I face the jets up toward the surface of the water or down?
2. I have a return jet in my submerged spa. Should I open the valve to allow some of the pump flow directly into the spa or save that flow for my pool jets?
3. I also have 3 bubblers in my tanning ledge. To optimize skimming, should I leave the bubblers on or should I turn them off or low and divert that flow more to my return jets by adjusting my valves
2. I have a main drain and two skimmers. If I understand correctly, I should adjust my valves to barely open the main drain and give the skimmers for the vast majority of the suction
