- Oct 7, 2022
- 16
- Plaster
- Autopilot Digital Nano+ PPC2
I just started my second year in this house and the pool has been fine mechanically. Its about 15 years old and the pump motor was replaced before I arrived but never saw this until last Saturday. I switched the suction and return valves to use the spa (first time in about two months) and discovered the pressure gauge on the cartridge filter had jumped from about 12 to over 20, the above ground pipes vibrating and sound of turbulent water near the valve, and there was now a slight crack in the top of the filter housing. I shut off the pump and after replacing the lid on the filter started troubleshooting. In normal operation it appears fine - there are two return jets in the main pool and one in the elevated spa that generates a small waterfall. No vibration or unusual sound.
In spa mode the primary return valve directs all flow into 4 separate jets in the spa. As I slowly moved the valve the pressure started increasing after I passed the halfway point and vibration and turbulence showed up. I stopped moving the valve and checked the output of the 5 spa jets. There was a small, even flow from the 4 spa mode jets and a stronger flow from the main jet (all are the same diameter.) I move the return valve back to main pool mode and pressure returned to normal and vibration and sound disappeared.
I did open the return valve and there was no visible problem. I pushed a plumbers snake into the spa pipe and didn't run into anything in the first five feet. I figured the pipe took a sharp bend at that point and decided not to force it further.
Any ideas? I clean the filter about once a month so I had the system open since the last time we used the spa but nothing unusual happened then or otherwise since then.
