Hi, we bought a home last fall which came with an Intex metal frame pool. Unfortunately it looks like the SWG that came with it doesnt work. I tried cleaning it using vinegar and connected everything back together. I keep getting the code 91 for low salt. After reading numerous posts on this very error, I was wondering if I should just go back to chlorine. I am not sure if it is worth buying another SWG this year. I might just invest in another pool next year maybe go for an inground one. What do you think I should do.
Where can i get the test kits mentioned on this site? as of now after running the filter, adding the salt and even though the generator keeps beeping on 91 code; the water looks much better than before. the Test strips show 0 FAC;0.5 TCI; 180 Alk; 8.4 PH; 250 TH; 30-50 CYA
The weather has still been too cold for swimming but I have bought a solar cover and this should warm up the water considerably from all the information I have read on here. Can you help me with suggestions on how togo back to a simple chlorinated pool?
the water we use is regular municpality water.
Thanks
Thanks
