Leak at hoses
I have a 21 foot round above ground pool and when we connected the hoses to the fittings I have a leak. It drips about once every 45 minutes to an hour. My husband says its fine and you cant have a pool with "No Leaks" and I disagree. we also have a small leak at the thread of a fitting going into the sand filter and I was just wondering how to fix it. They are rubber hoses with clamps and the fittings are plastic or PVC.
Umm I don't stand out there I go out every 45 mintues to an hour so I am assuming because there is not a stream there is a water spot and about the same if not a shorter amount of time. It is were the hose connects to the adapter or fitting to the Chlorinator
