f3justusc
Pysiek, if you have a craft store closer, they would sell them too. If it's only temporary and then you will have ball valves I am with the suggestion to just stuff a rag in it.
I can wait if I have to. For now I can connect the pump using the supplied hoses and then just wait for the valves.You can get Jandy valves or pool specific 3 way valves online as well, but it's pretty clear you're not gonna wait for that!
Thanks for the advice.I would put the a union between pool and pump, and another between filter (or heater) and pool. Basically, be able to completely isolate the pool from the equipment for maintenance.
It looks like I have to hold on with the hard plumbing. My Hayward In-Line Chlorinator requires this kit to be hard plumbed : Hayward Connector. I might purchase more for the pump and filter also.
Can you tell me where did you purchase them? Maybe post a link to a website?You don't need that kit. I also have a Hayward Chlorinator and just used standard threaded PVC adapters and/or unions. It uses standard sized connectors (see my signature link for pictures).
Dino
Where did you purchase it?I do have a check valve. It's dark out now I'll take some pix tomorrow.
This is the one I have:
http://www.pentairpool.com/pdfs/SpringCheckValveUG.pdf
Mine too. The only thing I noticed is the fitting on pump,filter and chlorine dispenser are pretty tight. And when I put the 1 1/2" PVC fitting to skimmer it was very easy to screw in with hand. I just hope it won't leak.I guess Hayward has changed things? My pump/filter are working just find with standard 1 1/2" PVC connections.
