700 CH with Flakes
SuperMiguel
139
Florida
Hello, since i got my pool 3 years ago there has been a struggle with CH, for some reason it keeps raising to pretty high level, currently at 700.
So some background built new pool, pool vendor handle the chem for few weeks passed to me, i dealt with it for a bit and noticed my pH will increase rapidly, requiring sometimes more than a gallon per week, eventually i hired someone to look after the pool (guy been doing it for 40 years) after i while i noticed calcium flakes, fired the guy CH was over 1k, drain water for a while added soft water, maintained my self and eventually got it down to around 400. Hired another well known pool company that many of my neighbors used, after few months the flakes are back they tried to fight it with acid, that fixed it for a few weeks, but flakes are back CH is around 700. Note when pool gets flakes so do my salt cell. Also when i use the heater that seems to increase the flakes
In my opinion is lack of acid from their part but they claim is my pool finish releasing it, that acid is perfect. Just trying to get you all opinion.
Edit just got some results from a 2 year old test kit: and test strips
Note: pool cleaning company came today and added acid, not sure what else they added (few hours ago)
FC 7.0
pH 6.8
TA 40
CH 550
CYA 20
SALT 3600
Water Temp 93
Flakes are usually produced within the SWG cell during chlorine production. High levels of CH and TA contribute to the scaling. Can you post a full set of test results.
You get pretty much your pool volume in rain overflow annually in FL, with rain being 0 CH.
Most by you struggle to maintain CH.
Do you/they use non-stabilized shock (cal-hypo) ?
Just got some results from a 2 year old test kit: and test strips
FC 7.0
pH 6.8
TA 40
CH 550
CYA 20
SALT 3600
Water Temp 93
You need to update your test kit. I don't believe the results listed are accurate. The results show very low ph and TA. There's nothing in that chemistry that would indicate scaling other than high CH which is likely not accurate either.
If those numbers are accurate and consistently maintained, you should see no scaling in the cell. Your TA is a bit low. TFP recommends an acceptable minimum of 50 ppm. Your CYA is also lower than recommended for a SWG pool.
As mentioned in my previous post, I would update the test kit and monitor levels on your own.
Update: got a new KIT yesterday (TFtestkits) and tested water today:
FC 15
pH 8.2
TA 70
CH 625
CYA 60
SALT 3800
TEMP 90
CSI 0.63
Also i went to look at the Cell and there is visible calcium on it, also I just noticed that my Jandy TrueCrear has an error saying Check Cell, not sure if that is because the high FC, the High Salt, the calcium shorting it, or that it just went bad :(
So at this point i think i need to fire my pool guy and start doing it my self :( and will clean the Cell with acid and figure out if i need to make a warranty claim for it.
Your CH is getting up into the higher ranges. Your pH is likely too high, but the test is not valid when FC levels are above 10 ppm. Let FC drop and retest pH. These factors are causing your CSI to be too high. For a SWG pool, CSI should be maintained between 0.0 and -0.30 to mitigate scale. Lowering your TA to 50-60 will also help. Did you add liquid chlorine or did your SWG get your FC up to 15 ppm.
I don't know much about your SWG system. Does it visually appear to be producing chlorine? Do you see bubbles in the cell or from the returns?
How old is your SWG cell?
2 years
Super Miguel = I like your avatar, I'm glad you adopted my suggestion!
I would not clean the cell with Acid...Here is the guide to cleaning.
YES!! Thank you, let me check that link and clean it that way
Yeah i think i might have to drain some water to lower my CH :(
Great cant get my Salt cell to work, and they are on massive backorder, so i guess i need to add Chlorine manually until salt cell is fixed? The only good news on this is that my pH levels are stable for the first time in 2 years
