Having a large gunite pool built with a spa. It seems to be coming out somewhere around 56,000 gallons.
The PB had spec'd out a Jandy Fusion Soft and I don't think that makes much sense.
1. That is rated for 40k gallons max which I'm well over.
2. The more I read I don't want the minerals / metals from that.
I'm wondering...
1. Should I get an Aquapure instead? (if I want to go salt)
2. Or just get the Jandy Fusion Soft and ignore the mineral cartridge?
3. Get a Jandy Tablet feeder and forget salt? (maybe easier to just manage chlorine tablets with all the gallons)
4. Double up on some option below. IE: get two Aquapure 14s that are rated up to 40k gallons each? I assume one can do that?
The rest of the system is Jandy so did want to stick with them. Getting the IAquaLink etc. It seems from my reading both the Fusion and the AquaPure systems work with the IAquaLink but as they already spec'd out a fusion I don't know if switching to an AquaPure is a big deal? Do I need to get a:
Or do fusion / aquapure use same thing? I've called Jandy a few times but never get past hold.
Any help greatly appreciated!
I'm wondering...
