My city tap water CH is 300-400
so the empty-and-refill method is pointless.
I researched pool water reverse osmosis in the Phoenix area and found only two companies.
Calsaway uses a truck-mounted self-powered high-pressure RO system that takes 1-2 days.
http://www.calsawayphoenixwest.com/
I was quoted $475.
HiTek Aqua Systems d/b/a Aqualabz uses a smaller RO system that takes 3-7 days and uses the homeowner's electricity ($5/day at highest rate).
http://www.aqualabz.com/
I was quoted $300.
Aqualabz calls its RO system EcoKlear. It's manufactured by Clean Water Products in Tuscon.
http://www.cleanwaterproducts.net/Swimming_Pools.html
I decided to go with Aqualabz because of the lower price. I will post an update after the service is done.
Current levels:
total hardness 1000
CH 750
CYA 150
salt 5200
I find these numbers disgusting considering that the pool is only one year old. After I get the water ROed, I will use the BBB SWG w/ borax method.
Because my city tap water CH is so high, Aqualabz is going to try to get the pool CH down to 200.
My house has a water softener (for the interior plumbing), so maybe I could try to tap into a pipe from the outside and connect to the pool auto-filler (instead of my back yard hose bibb, which is unsoftened). If anyone has any suggestions about that, please post.
