Okay so We had the pool built In 2016 and in 21' the motor was replaced. About 3 weeks ago my pool guy noticed a leak and said shaft seal. I ordered a new shaft seal and upon disassembly the guy who replaced it in 21' cross threaded one of the bottom stainless bolts that screw Into the pump plate with the brass Inserts. No one will take responsibility (Jamdy nor the company who did install) so I think i want to move away from a jandy motor. 1st the whole thing is completely corroded(underbelly and the actual flange) 2 Motors is Crud IMO. SO ANY SUGGESTIONS OF A MOTOR that will bolt up to a jandy square flange pump?
