Roland,
I hear your frustrations, but the questions I asked you were so that we can eliminate any misunderstanding on your part of what our method is. You did not answer my questions.
Have you confirmed you are done shocking? We know your water is not clear, so to confirm you are done shocking please confirm that your CC is 0.5 or below and you have passed the overnight FC loss test. An updated set of #'s would help as well. At least FC, CC, PH and CYA. Bruce tested your water and the CC level was 5ppm, if I recall correctly? It takes a lot of chlorine to burn that number down.
After we confirm you are done shocking, then we can move onto the filter issue. I'm not familiar with cart. filters, but is the valve actually set to filter, instead of bypass?
We're trying to help you accomplish your goal, and that is to clear your pool and hopefully avoid you having to buy a new filter.
Trust us that the methods work, the forum is 17,000 members strong, so if we were trying to pull a fast one on you, someone would have already chimed in with their red flag. Just my two cents...we are here to help, so if you have some test results that would help us help you. Dumping chemicals blindly into your pool will not.
