Hi Fellas,
First post on the forum, I just found the site and it has already been very helpful. I'm having a little bit of trouble getting a heater running. My LCD screen does not work very well, I can only make out what it says late in the afternoon when there is minimal glare. I ordered a replacement. In the interim, the modes are few and simple to interpret what the unit is trying to do. Modes are OFF/SPA/POOl. I can make out when it is set to POOL or SPA and it initiates the CFH, as I have the temp set high.
Symptoms - I see CFH then SPRK then it shows the temp of water (51) and set temp (80). I can visually see the pilot is lit and remains on but I get no main burner.
I can't tell if there are any codes. I pulled the pilot out to make sure the flame sensor is inline with the flame and I tested all of the safetys. I checked continuity on HL1, HL2, Roll-Out, pressure/flow and all check out ok. I looked at all the wiring and it appears to be sound - no mouse chew damage or cuts. Hours later...
I am suspecting either the PCB board or the gas valve. Using my multi-meter I verified 24v on the P terminal (red) when checked against the common (yellow), when I check the MV terminal (purple), I only get 1v. Not having that much experience my concerns are the following:
1 - It can be a bad PCB board, which is why I'm getting the 1v which explains why the main burner is not kicking on.
2 - Perhaps there is a safety which is preventing the PCB from supplying 24v.
3 - Gas valve is not initiating burn, but it would need 24v, so not convinced it is the valve. How can I rule out the valve?
Questions:
1 - While I wait for a new LCD, what else can I do?
2 - Should there be 1v on MV terminal? Is that a typical voltage when not putting out 24v or is that a fault in itself? Pointing to a bad PCB board.
3 - If it is a common voltage when the PCB board has a safety triggered, which one would you suggest I check again? More importantly, what is the best procedure to rule it out?
Equipment Details:
Unit: Raypak p-r336a heater
PCB board - 601769
Gas Valve - 003900F
Questions:
Equipment Details:
PCB board - 601769
Gas Valve - 003900F
