Question for electrician day - anyone have anything they wish they added around pad/inside enclosure? Right now only add is a dual exterior/interior outlet at the rear of the lanai
Great ideas, thanks as always everyone Paver base prep ongoing today !+1 on the pad light. I am adding one in next week or so. It will be a double gang - switch for light and extra outlets (GFCI).
You can never have enough outlets. There is always a need to plug something in that you don't have now but will in the future. Example - dry/wet vac for clean around pad or adding a camera to watch your pressure gauge, etc.
It will be pebble tech and from what I understand they are pretty mituculous and bring in about a dozen crew members. I watched another build in our neighborhood even continue through rain by them quickly and promptly putting in temporary tenting and tarpingThat looks GREAT!
I am kind of surprised they put up the cage before they did the plaster. They are going to have to double up the over spray protection!! I would make sure the edges are well overlapped to keep the plaster over spray off the mesh!
