I wouldn't suggest going over 30ppm of CYA until your pool is crystal clear. Why not switch to plain bleach/liquid chlorine at this point?
Maddie
Maddie
Day 16
The pool is almost there. It continues to clear everyday and I can see the main drain at the bottom of the deep end. The pollen has been heavy and it hasn’t helped, but the pool has kept on trucking towards clear. I should be in the clear by Saturday.
Since I am close to the end I started using tri-chlor tabs to help raise the CYA levels while also adding to the FC levels. I also started adding enough stabilizer to increase the CYA levels to 40 ppm. Normally I would stay at 40 ppm for the duration of the summer, but I plan on adding a SWG within the next week. So I will have to increase my CYA levels beyond that.
Looks like my Ph is a little low so I’ll have to add some Borax to raise it. I’ll probably wait until the pool is clear before tackling my Ph levels and before I start adding salt to the pool.
My current numbers:
FC - 7
CC - 0
PH - 7.2
TA - 70
CH - 180
CYA - 20
Salt - 1600
at least two months from opening....
