I have a Pentair Warrior SE bought in June of 2020 (so just out of warranty) that is no longer working.
It starts its initial test sequence, goes forward and reverse, pauses, then shuts down.
I've had this happen a few times that was due to hair being wrapped around the prop on the pump. I would clean it and restart and it would be fine. This time there is nothing obstructing the prop and preventing it from turning, but that is the issue. It's not turning the pump on to move water, verified by checking with my hand under water with it while it's trying to begin.
I wonder if hair wrapping around it could over time have burned that motor up, and if that is maybe likely to be my problem?
If so, is that motor a part that I can order and replace to get us back in business?
Thanks!
Thanks!
