- May 19, 2011
- 66
- Vinyl
- Hayward Aqua Rite (T-15)
Hey there everyone I’m scratching my head!!! I’ve started slamming my pool cause the pool was clear and looked like there was either a lot of dirt or sand out of the sand filter in the middle of the pool so I started sweeping the pool walls and floors and water turned a greenish color and real cloudy... I vacuumed the pool and tested and I’ll post pre slam results and results before I started slam... I made sure everything was in order...
First Test:
FC -0.5
CC - 0.5
PH - 8.0
TA - 90
CH - 210
CYA - 30
Salt - 2400
Borates - 30
Added Some Muriatic Acid To get PH down before starting slam App told me to add 48 oz to get PH to 7.3 - 7.4 I waited an hour and retested...
Second Test:
FC - 0.5
CC - 0.5
PH - 7.1
TA - 60
CH - 210
CYA - 30
Salt - 2400
Borates - 30
Now I know there’s no need to test all of that but I like to see where everything is at before starting...
So I started my slam at 10.30am and added 242 oz = 2 bottles of 8.25% bleach and that took my FC to 15.0 I know my slam level is 12.0 but thought it wouldn’t hurt!!! I tested again at...
11:30 - FC - 15.0
12:30 - FC - 13.0
2:30 - FC - 13.0
3:30 - FC - 13.0
4:30 - FC - 13.0
8:30- FC - 13.0
So I didn’t have to add a single drop of bleach all day... <—- “scratching my head”
Anyways at 8:30 I went ahead and added a gallon of bleach to get it up because we were gonna be leaving early in the morning and we’re gonna be gone for a while FC went to 20.0 so I overslept a bit and woke up at 8:30am and tested and I was at FC - 20.0 <— “scratching my head again” So we didn’t end up leaving anywhere after all so I got to test again here are my results
10:30- FC - 17.5
3:30- FC - 17.0
6:30- FC - 17.0
Was doing yard work so didn’t test as frequently... anyways that’s where I stand as of now... haven’t had to add anything and it’s not going like a regular SLAM would... the temps yesterday were around 56-58 and today around 68-70 I had read on here somewhere that the cold water doesn’t affect FC or CC readings so you don’t have to wait and get it to room temp before testing... So does anyone have any idea why I’m not having to add or why my chlorine isn’t getting consumed? The water is still a bit cloudy but the green went away right away after adding the bleach and sweeping the pool... any advice would be greatly appreciated...
First Test:
FC -0.5
CC - 0.5
PH - 8.0
TA - 90
CH - 210
CYA - 30
Salt - 2400
Borates - 30
Second Test:
FC - 0.5
CC - 0.5
PH - 7.1
TA - 60
CH - 210
CYA - 30
Salt - 2400
Borates - 30
11:30 - FC - 15.0
12:30 - FC - 13.0
2:30 - FC - 13.0
3:30 - FC - 13.0
4:30 - FC - 13.0
8:30- FC - 13.0
10:30- FC - 17.5
3:30- FC - 17.0
6:30- FC - 17.0
