Has anybody had any luck with Natural Chemistry CYA reducer
My pool is at about 200 CYA.
Thanks
Thanks
Thanks!!May give it a shot. Its $40 for a treatment. I will post results if I do this.
Thanks
Sounds like CYA is a very “stable” chemical. It will not readily break down or be transformed into another type of molecule. Only something biological can change that apparently.
To be honest, it probably didn’t do anything. It is impossible to accurately test CYA to the level you are reporting, so I’m guessing those are numbers from a computerized pool store test. You should never confuse the specificity of those tests to accuracy. The CYA test is jut not that accurate.Just tried this product on advice of my pool tech....huge pain to monitor FC and negligible result—went from 68 ppm to 63ppm. Wouldn’t do it again.
July 2021: I used Bio-Active Products Pool Stabilizer Reducer/Cyanuric Acid Reducer in April 2021 after Taylor CYA test results showed CYA of ~200ppm. Followed package directions scrupulously. After treatment Taylor test showed CYA of ~50. It's been creeping back up, of course. The current anomaly is this: Taylor testing gives pretty regular reading of ~75, but I took a sample to Leslie's yesterday just for some double-checking and their testing reported CYA of 158. My Taylor reagent is brand new, so it's not an outdated product issue. Anybody using the Taylor High test kit also getting variant readings from a pool product company test?May give it a shot. Its $40 for a treatment. I will post results if I do this.
