Hi All,
I just moved my family in to a wonderful home that we waited nearly 1 and 1/2 years to find. The first time we viewed the property, I told the wife that the pool was "going, first thing". It was obvious it was not well cared for, unkept, filled with tree frogs and their offspring, greener than the lakes I swam in as a kid.
Well, last week she consulted the "pool guy" who made it clear that at some point, someone had spent a lot of money on this structure and it would be a shame to see it go to waste (we have 3 young children who will likely enjoy it). SO....as a good husband must do, I complied to at least look into what it will take. Needles to say, I am in way over my head, and don't have a clue as to what I am doing. He said he thought the filter/pump/etc. "looked good"...well, they weren't. Bought new pump as the old one began smoking as soon as I plugged it in opened up the filter and cleaned out old sand and replaced with new so I knew what I was starting with. The valve seems to work, at least for now.
Pool drained to about a foot:
Current situation after pump running 24/7 for 7 days, roughly 12g of 10% chlorine, 1/2 gal Acid, constant skimming, backwashing roughly 3x/day, and running the vacuum "robot" thing the previous owner left, not sure if its a "good" one (aquabot???): :
I bought the Taylor K2006 kit and received it today. I got really backed up at work and hadn't added any chlorine x2 days.
Tests today:
FC: 0.2ppm, restested an hour later and got 0, pretty sure I didn't do it right the first time.
Combined: 0.6ppm
pH 7.4
TA: 340 SHEESH
Calcium: 50ppmI still have some algae solids when I run the skim net along the bottom in certain areas, but can't see the bottom. Can see objects (net) until its beyond 3ft deep (4ft total depth).PoolMath says for 15000gal pool, to add:
77oz 10% bleach
nothing for the TA, but I'm wondering if I need to add more acid to reduce pH some more (if lower to 7.0, PoolMath says another 130oz of Muriatic acid)
466oz of calcium chloride
I did not test CYA as I have read it is pointless to do so at this point.
Does anyone have any suggestions as to how I should go about my next steps? Should I buy the calcium and acid and add both at the same time?
Obviously I'll keep the filter running, but how many times do I need to be backwashing a day? I just bought a new pressure gauge because the previous one was not working.
Thanks so much for any help, I've done quite a bit of reading on here already, but this is definitely way more time consuming than I ever anticipated...I still have to work some time!
Forgot to add, after seeing the FC: 0 tonight, I went ahead and added another 2 gallons of 10% before coming inside.
Tests today:
Combined: 0.6ppm
pH 7.4
TA: 340 SHEESH
77oz 10% bleach
