View attachment 84675View attachment 84675
Stuff is starting to happen. Fast. The pool has been gunite'd. The tile has been placed. The rails for the autocover have been installed. We had to wait a month for the concrete guy to start on the decking. He started on Monday. In five days, he
* Graded both of the main pool decks, one on the downhill side, one on the uphill side.
* Built the forms for the retaining wall for the main downhill-side deck.
* Graded the uphill area for the solar field. We decided to have him pour a slab for that, for a trouble-free installation.
* He also put a bump-out on the uphill deck, so we can have a shed or gazebo up there.
* He trenched for a electric socket on the uphill deck.
The pace of work has been nothing short of furious. At one point, he had THREE earth moving machines on my hill.
A small setback yesterday; we scheduled an inspection for the retaining wall forms. When the inspector arrived, they were
finishing up positioning and fastening the rebar. The inspector refused to inspect, and read me a lecture about scheduling
inspections for unfinished work. The contractor was fit to be tied. He had to call the concrete company, cancel the delivery, and put it out another day. In general, this particular inspector was one of the more sour ones I've encountered. He emphasized that as an owner-builder, I would be responsible for any reinspection fees.
My own little contribution to the project: A pedestal for the autocover keyswitch. It consists of a square box, fabricated of 1/8" thick mild steel, that the plastic autocover switch box will slide into. Welded to a piece of 2" steel tubing ( also 1/8" wall thickness ) that will hold it at a decent height. To make it a little less industrial, I obtained a cast steel frog sculpture to weld on top.
View attachment 84676View attachment 84676View attachment 84677
I also plan to obtain and mount all necessary fencing and railings. I might have to switch our two exterior gates from opening inward to opening outward. We'll see. If the inspector makes me, I'll do it. We have reasonably good metalworking equipment - a MIG welder, gas welder, TIG welder, plasma cutters, a metal-cutting bandsaw: this kind of simple ironworking is a piece of cake.
In addition, the sauna we ordered will be delivered as a pile of wood that you put together. And also the shed that my wife wants. Gonna be a busy September.
Urp. Big setback yesterday. County inspector came out "You need a permit for that retaining wall". The contractor had decided that it didn't need a permit because it was 4 feet high - four feet from what? From Grade. The County OTOH measures it from the BOTTOM of the footing. Five feet, need a permit.
The thing that bites is that I had had a retaining wall engineered. It was a cantilevered wall ( which is what the engineer likes, and his software supports ). I had emailed the contractor the drawings from the engineer "Can you build this?" "Sure". But when he came out, he built the wall *he* liked ( gravity wall ). Read me a lecture about how it didn't need to be engineered, and how I had wasted my money on the engineering. I didn't insist, I trusted to his experience.
After a bit of grumbling, he took it with good grace, and his crew is taking apart the unapproved forms. I figure that's on him; because he HAD the engineered plans, and chose to ignore them.
...So I went to the County with the engineered plans and calculations. They said "We'll issue the permit in four to eight weeks. Maybe sooner because it's an addition to an existing permit and you're in the middle of your project."
