- May 3, 2007
- 18,094
- Plaster
- Hayward Aqua Rite (T-15)
Why is there 15ft static head? Doesn't the suction and return go back to the same place and net to zero?I've had this question a couple of times and just didn't worry too much about it. But I do get the point and I could easily do that. That would mean it will have to do spa duty as well. With 10 jets in the spa should need 100 gpm. I might be a little light on flow rate but I could close a few when we're not using them. Just looking at the filter gauge at 3000 rpm I think it was 10 psi, so say 22 ft head plus say 15 ft of elevation plus dynamic piping loss.
Or is this because you are using the filter gauge which is 15' above the spa? But that doesn't make sense either because of priming.
