- Jul 21, 2013
- 65,437
- Plaster
- Pentair Intellichlor IC-60
50’ lift 6” at a time = 100 cycles?We're lifting about 5.5' and the spec is 10' max so that shouldn't be a big issue. I've got 4" pipe to the pump suction where we reduce to 3" straight to the suction flange. I think part of the difficulty is that we've got about 50' of 4" pipe to lift through and the prime cycle isn't long enough to get water up to the check valve.
This lifts the water in the suction pipe about 6" each time.
Or
5.5’ lift 6” at a time = 11 cycles?
