- Oct 25, 2015
- 5,826
- Plaster
- CircuPool RJ-60 Plus
Thank you again for the help!Looks fine with plenty of headroom.
- One of the gunite bidders has a question about steel matting in the zero edge trough section. Drawing shows single layer but he typically sees two. I've asked him for advantages from construction perspective. What do folks on here think?
- What are the current preferences of folks here. Last I recall it seemed that Pentair Intellibrite seemed to be favored.
Thanks Allen, very helpful.Two layers has to be stronger then one.
What is the cost difference?
Really no changes in the pool LED light market.
All Pentair lights have various reliability issues eventually that are described in Pentair LED Pool Lights - Further Reading
Intellibrites overheat and burn up the electronics. GloBrites crack and leak and Microbrites eventually get water leaks in.
I would use nicheless Microbrites in a standard 1.5" pipe. Before installing the Microbites I would place a bead of clear silicone sealant around the back of the clear lens where it meets the casing and let it dry for 24 hrs. And seal the back of the casing where the parts connect together.
Pentaire Globrite LED light leak
I have 4 Pentaire Globrite color LED lights in my 3.5 year old pool and all 4 LED lights have failed after filling with water. After reviewing the web and forums like this one, this seems to be a common problem and many have blamed a faulty o-ring on the front of the light. However, I also...www.troublefreepool.com
Using the 1.5" nicheless lights you will have the widest range of non-Pentair lights, like CMP, in the future.
You will need more lights as Microbrites have less lumens then Intellibrites.
Pentair guideline is to aim for 4 lumens per square foot of pool surface. For example, if the pool is 500 sq-ft then you need 500x4=2000 lumens. This would be 4 MicroBrites or 2 IntelliBrite rgb.
Yep, I agree. One of the bidders has indicated they won't spray the job unless it's double matted. They're the most qualified bidder so that's good enough for me.Two layers has to be stronger then one.
Allen,Allen,
This is extremely helpful as well. I built a spreadsheet as you suggested, can past in Excel format very well so below is a screen clip. Does this make sense and look OK to you?
Chris
Allen,
Just got 3 of the conditions changed to "met" today with my submittals earlier this week. One of them was electrical. Looks like the load list submitted using your suggested format worked like a charm. Thanks!
Sub Checklist | ||||||
Materials | Labor | Insurance | License | Specification | ||
Gunite | Pool Design Docs | |||||
Excavation | As agreed w/ Forming sub | |||||
Haul out | ||||||
Forming | Pool Design Docs | |||||
Wood and Other | Pool Design Docs | |||||
Rebar | Pool Design Docs | |||||
Plumbing (to pad only) | Pool Design Docs | |||||
Temp pump | Pool Design Docs | |||||
Plaster | Dimond Brite Bahama Breeze | |||||
Pavers | Belgard Lafitt Grana Napoli | |||||
Electrical Wiring | Pool Design Docs | |||||
Pool Lights | Pool Design Docs | |||||
Bonding | Pool Design Docs | |||||
Enclosure | TBD | |||||
Equipment | Pool Design Docs | |||||
Main Pump | Pool Design Docs | |||||
SPA Pump | Pool Design Docs | |||||
Controls | Pool Design Docs | |||||
Filter | Pool Design Docs | |||||
RO Unit | TBD | |||||
Heater, propane | TBD | |||||
Heater, solar | TBD | |||||
Pool Cover | TBD | |||||
Robot | TBD | |||||
Landscaping | Building Permit | |||||
Survey | Building Permit | |||||
Permit & Inspections | Building Permit |
A lot of this was included in the various different subs but I can't believe I forgot the SWG! Thank you Allen.
- Skimmers - type?
- SWG
- Spa Blower or Venturi air piping?
- Spa jets?
- Spa jet air/water manifolds to be used?
- Drain type in pool and spa - channel drains? round ones?
- Hydrostatic drain in bottom of pool?
- Pad plumbing & valving
- Coping
- Tile & tile applications materials & process
- Provision for expansion joint between bond beam and deck
- Recent discussion about installing suction/pressure cleaner line even with robot given state of robot tech and economics
- Drainage/water management between pool and house on deck
I had mine in hand before signing the build contract. After 8+ years with one, It was *that* high on my wish list.I can't believe I forgot the SWG!
Impossible for me to evaluate what is missing without seeing all the documents.A lot of this was included in the various different subs but I can't believe I forgot the SWG! Thank you Allen.
Allen,Impossible for me to evaluate what is missing without seeing all the documents.
Your list had pavers and plaster but not coping and tile. Hmmm…
