Thread: Liquidator
    Mar 2018
    El Dorado Hills
    1
    Liquidator
    I am having issues with my liquidator developing build up in the lines. I am not sure if it is scale or salt buildup. My pH levels are around 7.4 and chlorine around 3 ppm. Calcium is a little high around 300. I have had liquidators for five years with no issues, but lately it is a daily hassle needing to clear lines. The flow meter and valves also get clogged and stop or reduce flow from the build up. Please help!
    JoyfulNoise's Avatar
    May 2015
    14,225
    Re: Liquidator Question
    It’s a mixture of salt and calcium scale that’s a fairly common problem with the liquidator. What kind of liquid chlorine strength are you using - 6, 8.25, 10% ? Have you recently changed brands?
    You may need to just drain and disassemble the unit to properly clean it all out. Old tubing should probably be replaced and the mechanical components can be soaked in cleaning vinegar to remove the scale build up.
    Matt
