- May 23, 2015
- 24,490
- Plaster
- Pentair Intellichlor IC-60
I’m afraid of getting selenium stains on my dentures....how does one remove selenium stains? Gargle with dry acid?
Selenium is odorless and insoluble in water and alcohol, but soluble in chloroform, methylene iodid, benzene, quinoline, nitric acid, sulfuric acid, ether, carbon disulfide, aqueous potassium cyanide and potassium sulfate solutions.
http://scorecard.goodguide.com/chemical-profiles/html/selenium.html
Personally I do think I have been a bit molybdenum deficient lately. I was going to chew on some 316L stainless steel screws but thought the water might be more refreshing....
...You'll be healthy, wealthy and wise. You'll be saving the planet, righting wrongs and bringing hope, truth and justice to disenfranchised, underappreciated humans around the world.
I wonder why it has moly in it. I use moly on my ammo reloads and the instructions say not to touch it barehanded.
The transition element molybdenum (Mo) is of essential importance for (nearly) all biological systems as it is required by enzymes catalyzing diverse key reactions in the global carbon, sulfur and nitrogen metabolism. The metal itself is biologically inactive unless it is complexed by a special cofactor.
