Pb says no, he will cover it, but I am curious if I should upgrade to IC60 swcg??
GREEN is good! SWEET!
So what are the two big round things on the side of the pool? They look like main drains but you have those on the bottom where they should be.
Kim
Brian,Those pots are the same ones that some builders use for the main drains. They will get drain covers installed on them and since they are split there is no risk of entrapment.
It is very common to use wall ports for water features like you have. Looks good
Brian,
thanks! Glad to hear that it is okay. I know the waterfall pumps don't pull near as hard as circulation pumps, but it still made me a little nervous like Kim said.
Brian THANKS! Greg you can take what he says to the bank.
I wonder if you can use these kinds of covers to help "hide" them?
http://www.poolfittings.com/
Kim
