So what is the time line now?
Kim![]()
PB can adjust the flow (and pressure) using different diameter eyeballs in the returns. That's easy enough but I am not really sure why he wants to do it. I would talk with him and ask about placement and that you notice many pools with only 2 or so returns. His answers should make sense.
6 returns is probably OK but you will have a decrease in your system pressure and the flow. That may not be bad but you should understand where and why he wants to put them.....they could be a very good thing.
Ask him how the pressure is adjusted with the eyeballAll the eyeball does is tell the water from the return where to go. I guess you could adjust the pressure a tiny bit if you have the eyeball turned so it is blocked a little bit by the ring that holds it on.
It is YOUR pool and YOUR money. Tell him what you want and keep looking him in the eyes while he tries to wiggle out of what you want. Keep saying "I want 2.5" pipe" over and over until he gives up LOL Do the same thing for the valves to the returns. Having each set of returns on it's own valve will give you so much more control. If he does it like he wants the returns at the end of the return may have less pressure/flow.
Kim![]()
Nice choice of stone and tile. It looks very similar to what we wound up using, and I like the blue tile with the golden color stone. We went with real stone, and it turned out great.
PRETTY!!! I like it all!
What color of grout did you pick for the blue tiles? They should have sample sticks you want mess around with to pick from.
Kim![]()
Where were they?? Glad to hear they are back at your pool!!!
Kim![]()
