I have had a trouble filled summer and we are still running into a problem - I'm hoping someone can help!
So we installed a Omni logic automation system (had to return the first one because the display did not work). I have installed the T-Cell-15 with the Omni logic and verified the settings are correct. The salt level in the pool is ~2800-3000. The issue is the omnilogic shows 0.00V and 0.00A, with relay open warnings and voltage short alarms. We assumed it must be a bad a salt cell. Ordered another one and the same issue. Could the 2nd Omni logic board be bad? Is there any troubleshooting tips to try with the omnilogic/salt cell?
Thank you
Thank you
