So, I'm using 12.5% liquid chlorine. I was originally adding two 1g bottles a day and over the last two days have dropped down to 1.5. I just used the last of my stock last night and am now crunching numbers to see if there is any local alternative that comes out cheaper. Not finding anything at this point so I'll probably just go refill my crates today @ 12.99 for 4 gallons.
I know I'm most likely not at ideal SLAM levels, I'm guessing it might actually be higher than recommended, just trying to make sure there's no regression before I can test correctly.
And yeah, I've never had a PH issue before that I'm aware of and I had LPS (cringe) test prior to starting this and it was 7.4. I know I can't effectively test PH again until after the SLAM is done. Pretty much just counting on one CYA test, and as long as that is in a good range it'll just be FAS-DPD FC until I pass all 3 SLAM requirements.
