So I just picked CYA up at the pool store and was told I HAVE to use tablets or I will always have algae. He also said I can't use salt, ever. It will ruin my pool. A little confused here!!
Of course they would say that....by using an SWG you will never need to use pucks again. Which means you'll never need to go into a pool store again. Which means they have no more profit to make from you, ever again....as for their comments about salt ruining your pool, do a salt test on your water and I bet you'll be AMAZED at how much salt you ALREADY have in your pool water....
Before you convert to an SWG, you should put up a post on the forum to look at your electrical system and how everything is bonded together (don't worry about this now, it's for when you're done with your conversion). As long as your pool, pool water and equipment are properly BONDED (note: bonding is not the same as electrical grounding), then your pool should be fine.
And here's a bit of advice for dealing with the pool store -
1. Go into the store with a determined look on your face and make no eye contact (yes, it's a little rude, but that's how you have to be);
2. If you don't know where something is and it's not obvious, ask them for the exact thing you're looking for, don't give reasons or tell stories about what your doing, simply say, "Where can I find XYZ?"
3. If they ask, "How's your pool water?" Your answer is, "Just fine, thanks for asking."
4. If they ask, "Can we test your water for you?" Your answer is, "No thank you."
5. If they ask, "Why do you need XYZ?" Your answer is, "Because I need to get some..."
Treat the pool store like the car dealership - go in there knowing exactly what you want and what you will spend and do not let them talk at all...
