If you use a polyquat algaecide at the maximum dose I don't see how it could hurt. But keep up with the chlorine too. Make sure it's polyquat: anything else either has copper (which can cause other problems) or doesn't work.
The filter shouldn't matter in terms of green-ness. Although if it's having problems your water may stay milky blue when all is done. So no point deep cleaning until you're at that point. The filter doesnt kill the green... The chlorine does, then the filter cleans up the dead algae. If it's green, it's still alive.
Yes. The organic material in the deep end is likely eating up chlorine and hiding living algae. You need to scoop or vacuum to waste all of it. Use a leaf rake and just scrape along the bottom until you stop getting anything.
As for draining, for *most* vinyl liner pools, you can drain a substantial amount, usually as long as you leave a foot in the shallow end it's okay... But that depends on your water table. I would check into that before doing a big drain. If you just want to do a full drain that's possible too with some work. It generally requires a big winter cover or tarp.
