Mr. Bruce,
Thanks for the search time, I may start another thread to try and find out this mystery question of life, Meantime I will continue to to only turn Clockwise until I find out.
George
Yes it is, but I would check out TFTestkit.net, order 2 XL options, (If it is FAS-DPD reagents running low) a Speedstir, a 50ppm CYA standard and some CYA reagent. That will be over $70, get free shipping you should get it in 2 days (not guaranteed 2 day shipping but I always do, and you are in same region). I found they are best bang for buck. Dave, the person who started this does have an interest in this, but I do not. SO I figure best deal plus if it helps him and they support well, could even call an order and ask them about colors and accuracy, get answers to questions. Speedstir definitely makes testing soooo much easier. The 50 CYA standard is water with a known CYA of 50, mix it up, pour it to 50 and now you know what a positive test looks like, I ordered a second tube and mixing bottle also so I can have them side by side to compare.
Fingaling has some great points but I would hold off adding polyquat for a couple of days to see if Swampwoman checks in. She really is "The Expert" when it comes to turning swamps around, metals in pools and additives. Good info though, thanks Fingaling
Hows the back doing?
George
Ph does not read accuratly when FC greater than 10, CYA does not matter, I am not sure about TA and CH. Since we have vinyl CH not a big deal (or so I have read) Mine usually is about 100 (just where it naturally falls). Now you are asking questions that show may amateur status, but that is good because it shows how much you are learning. I will leave the color changes and accuracy of TA and CH to someone who knows instead of venturing a guess.I think this is good during SLAM because it lowers my shock level to about 12.
Is it ok to order more reagents for the Taylor k2006 from Amazon?
