Results 1 to 9 of 9
Thread: Stabilizer question
    kywildcats's Avatar
    Jul 2015
    Mayfield, KY
    609
    Stabilizer question
    I know the addition on Stabilizer to increase CYA will lower PH level, but will FC increase at all while adding? My FC numbers are not adding up this morning after two separate doses of it.
    Mark
    20'x28' IG, Vinyl, (Sept 2015) 14,900 Gallon, 3'4 to 5'6 deep, Jandy Proflo 1.5 HP, 220v, 2 speed pump, Waterway Carefree 27" 400 LB Sand filter, Digital Nano plus SWG, TF-100 test kit /speed stir. Dolphin Primal x3 robotic cleaner
    domct203's Avatar
    Jun 2015
    CT
    3,896
    Re: Stabilizer question
    Only if the CYA is in the form of Dichlor/Trichlor. If it's 100% CYA, no, FC shouldn't rise.
    How much of an increase are we talking?
    Dom - TFP Guide
    Intex 18' X 48" Ultra Frame AGP 6700 gallons | Two Intex CS8110 SWG's | Hayward Pro Series 21" Sandfilter | Hayward 1.5HP Power Flo Matrix pump | Hayward Thru-wall Skimmer | Wanda the Whale | 72 sq ft of Sungrabber Solar Panels with Hayward GLC-2P-A | Taylor K2006 Test Kit, Sample Sizer & Speed Stir | Click Here To Become a TFP Supporter!
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    20,301
    FC will not increase just from adding CYA. FC losses from sunlight will decrease so you won't lose as much in a day. You are adding FC via the SWG, so if FC is climbing, you need to lower the output percentage on your SWG or reduce pump run time.
    kywildcats's Avatar
    Jul 2015
    Mayfield, KY
    609
    Just regular 100% stabilizer added. Yesterday morning FC was at 4. I added 38 oz of 10% bleach to bring it to 6. Put solar cover on yesterday for the first time. Checked FC this morning and I am getting 7.5. My PH did lower from 7.5 to about 7.2 or 7.3
    Haven't turned SWG on for the season yet, just using bleach.
    Mark
    kywildcats's Avatar
    Jul 2015
    Mayfield, KY
    609
    Quote Originally Posted by domct203 View Post
    Just checked the CYA container to make sure. It is Clorox saltwater stabilizer. Principal Functioning agent is 100% Cyanic Acid.
    Mark
    kywildcats's Avatar
    Jul 2015
    Mayfield, KY
    609
    Tested FC this morning and it was at 5.5. Must have been a testing error on my part yesterday. Still learning!!!!!
    Mark
    kywildcats's Avatar
    Jul 2015
    Mayfield, KY
    609
    My CYA is not rising using Clorox Saltwater Stabilizer, or not enough too tell anyway!
    Mark
    Richard320's Avatar
    Jan 2010
    20,301
    Quote Originally Posted by kywildcats View Post
    If it's all dissolved and has had a couple days to mix, it should show.
    kywildcats's Avatar
    Jul 2015
    Mayfield, KY
    609
    I added 36 ounces (give or take an ounce or two) in two separate doses late last week and weekend. It started about 50 and is still hanging there this morning. I got 16 more ounces going in now.
    Mark
