Thread: Where to place a gas heater
    Exton, PA
    250
    Town has no code, so it's manufacturer's specs. Basically, 4 feet from any window. Those specs aside, here are my questions:
    1 - how far from the water, so the unit doesn't get splashed, etc.?
    2 - it's a Raypak 206, so how far of a run is too far, before the water is really "losing it's heat" in transportation to the pool.
    3 - any real options for encasing the heater?
    I have options, but none seem great. One spot is almost on the opposite side of the pool from where the pump/filter is. And still probably too close to the water.
    I'm afraid my only real option, far enough from the pool water, yes close enough to the pump, would be to place a 32" x 40" slab in my lawn. And that won't look great.
    18' AG pool, 7,646 gallons, Sun from 11:30AM-2PM.
    Pentair Dynamo 1hp pump, Intermatic Timer (6/17)
    Pentair Sand dollar filter - 100lbs, 35gpm
    Pentair Lil' Shark cleaner, TF-100 Kit
    Raypak 206A 200K, BTU gas (6/17)
    ps0303's Avatar
    Jul 2011
    FL
    3,919
    Re: Where to place a gas heater
    Preferably you install the unit within a few feet or closer to the filter/pump. If you have to position is further away, I would stay within 6 feet of your equipment.
    Encasing the heater?
    Paul
    Gastek Pool & Gas Services If you would like to provide a review of the help I provided, please use the following link to leave a review. Gastek Google review,
    Check out some videos on my YouTube channel - Gastekservices on YouTube
    Exton, PA
    250
    Makes me think about moving the filter, etc. as well. The liner has to be replaced anyway. Hmm...
    Encasing, I just meant a way to "hide it". Maybe just some lattice around i guess.
    Exton, PA
    250
    How far from the water (splashing water) should this be, or does it matter? I know the heater should not be in a place, where water can get in (up in), to the vents. But I don't want to be too cautious about splashing water. Is 3 feet from the pool water enough clearance?
    ps0303's Avatar
    Jul 2011
    FL
    3,919
    Think about it this way, if it rains, will the heater get wet? Of course it wouldn't be a tidal wave like kids splashing water all over. 3ft would be ok.
    Paul
