That is a sand filter.Can anyone tell me what kind of filters I need to get by looking at the equipment I have? With the previous owner running the pump all the time and the super cloudy water, I imagine I need to change the ones I have but I don't even know where to look. The deep end is far too cloudy to see what I am vacuuming but after vacuuming mainly the shallow end for 20 minutes both the vacuum and hose were filled with sand and small pebbles. Halp!
Cleaning it is really easy. You shut off the pump. You turn the handle on that big valve to the backwash position, and you turn the pump on again. I can't see in the pictures, but somewhere on that valve there is a waste port where all the filthy water will spew from. Maybe into that half-burred canister thing? Can't tell. It might be hard plumbed or there may be a connector for a hose.
Anyway, after 30 seconds or so, the water will be clear. Shut the pump off. Turn the knob to rinse. Run it another fifteen seconds or so. Shut the pump off again. Turn to filter. Done. More detail here: Pool School - Maintenance and Cleaning of Pool Filters
If you can get some better pictures of the backside of the multiport valve, it will help us figure it out.
This is the multiport:
