Thread: New Dolphin Nautilus Plus Smushed Rollers
    Jul 2011
    St. Paul, MN
    244
    I just received my new Dolphin Nautilus Plus today. The rollers were smushed where they were resting on the bottom of the box. I'm not too worried about the gray scrubbers, but don't like that the white foam parts are deformed. Should I return or do people think this will fix itself over time?
    20'x40' Oval 27,000 gallon Vinyl IG, Coverstar Auto Cover
    Hayward MaxFlo SP2303VSP, Sta-Rite PLD50 30 sq. ft. DE filter
    Rheem 266,000 btu natural gas heater
    Dolphin Nautilus Plus with Clever Clean
    TF-100 testkit w/ Speed Stir
    Mod Squad Jimrahbe's Avatar
    Jul 2014
    Bedford, TX
    9,248
    Re: New Dolphin Nautilus Plus Smushed Rollers
    Faby,
    They are not smushed, they just are not wet. They expand when wet and will be perfectly fine in the pool..
    I came within a millisecond of ripping them off as I thought they were just packing...
    Jul 2011
    St. Paul, MN
    244
    Thanks. I've been anxiously awaiting my new cleaner and would be bummed if I had to exchange it.
    Oct 2007
    Parkland, FL
    753
    Yep exactly right, those the rings to help it climb a bit better and will be fine once they are wet for a bit. full brushes like that are much more expensive. Good compromise IMHO.
    8000 gal diamond brite pool with 650 gal spillover spa, Pentair 3hp VS pump. Jandy Cartridge filter and Jandy Heat Pump. Jandy PDA automation system with 2 Pentair Laminars. SmartPool NC74S Robotic Pool Cleaner.
