Thread: Trouble with Polaris hose
    Dec 2013
    Augusta, GA
    96
    I have a leak in the hose for my Polaris 280. How can I stop the leak?
    IG gunite pool / 30,000 gal / 20'x 40'/ built mid 70's
    1.0 HP Hayward Super pump / Polaris PB4-60 booster pump
    Pentair SD-80 sand filter
    Intermatic mechanical timer (PF12222TB)
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,999
    Re: Trouble with Polaris hose
    I'm not sure to be honest. Is the fitting broken in some way? Cracked, bad seal? Fill us in more please.
    Essential Links:
    Dec 2013
    Augusta, GA
    96
    Quote Originally Posted by Patrick_B View Post
    It does not appear to be cracked or broken as far as I can tell. As the Polaris is moving around the pool, I can see water spraying out at this point in the hose.
    Reddogdan's Avatar
    Sep 2013
    Mansfield, Texas
    243
    Then try giving a a good twist. Sometimes with all the twisting and turning they simply come unscrewed.
    14.3k, 3 1/2-5 1/2, IG, Pebble Wet Edge Northshore Tahoe, Jandy 4 cartridge, Jandy 2hp variable, Pentair 320 inline chlorinator fed by a Stenner, Polaris 280, K-2006 test kit, Built 9/13
    Fill water: TA=90, PH=70, CH=90
    paulmaz's Avatar
    Apr 2016
    San Antonio, TX
    121
    I just had the same problem with my hose. You can replace the swivel. You need these parts. Not hard to fix at all.
    https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
    -Paul
    15k gallon IG plaster, 26x39 at widest points, sort of shaped like the great state of Texas!
    Pentair 342001 SuperFlo VS Variable Speed 1.5HP motor
    Tagelus TA-60 Sand Filter, Polaris 280, TF-100
    Morpheus321's Avatar
    Jun 2015
    St. Louis, Missouri
    5
    I agree with the "give it a good twist". This same thing happens to my Polaris from time to time. It is best to try fixing it with it running so you can see when the gushing subsides. It seems mine always has a slight trickle of water coming from that area, which, according to Polaris, is not abnormal. I can always tell when the trickle becomes more of a gush because my cleaner movement will become sluggish from the lack of water pressure through the hose. Good luck!
    4000 gal IG fiberglass (install 5/2013), 1.5hp Hayward pump, 325sqft Hayward cartridge filter (122GPM), Hayward Goldline Turbocell SWG, Hayward Aqua Plus automation with Aqua Pod remote, Polaris 360 pool cleaner, Taylor K-2006 test kit
