Thread: DE not sticking
    Apr 2017
    Tulsa
    1
    DE not sticking
    I'm having the same issue. The DE is not coating the grids, only in spots. I'm wondering if I have a problem with grease or oil?
    13k gal
    gunite
    Anthony Pools Apollo 40 DE Filter
    1hp pump
    Mod Squad Jimrahbe's Avatar
    Jul 2014
    Bedford, TX
    9,265
    Re: DE not sticking
    Tulsa,
    Welcome to TFP... A Great resource for all your pool and filter questions...
    I doubt you have a grid issue... When you backwash or open your filter, the DE will often fall off at some places but not so much other places.
    How you add DE is important also...
    Fill a five gallon bucket with the amount of DE needed.. (Use two buckets if needed). Then add water from a hose. You will be amazed at how much water will still fit in the bucket.
    Stir into a very thin mixture. Turn on the pump (at least 2500 RPM) and slowly pour into the closest skimmer to the pad.
    Thanks for posting,
