Had a pretty bad algae problem when I opened up this year and have been in SLAM for a while and can pass an OCLT. I’m pretty sure algae is gone. I have never added DE before but was hoping it would speed up the water clarity issue.
I added DE according to instructions (diluted 1/4 cup in a bucked, poured into skimmer, repeated until pressure went up 1 psi.) I knew that the pressure would probably go up pretty quick. So I checked after 3 hours. Baseline is 11 spa, with the DE it was at 12. When I checked it read 20 psi. I quickly backwashed and repeated the DE additive procedure. 3 hours later, it was at 20 again. Same thing happened a third time.
My question is this: is it normal for this to happen multiple times? I backwashed it this time and didn’t put DE in it since I can’t check it overnight. Should I keep doing it until the water clears? As long as I can watch it that is?
Thanks in advance for any help!!
