Results 1 to 10 of 10
Thread: Green pool.
    Feb 2017
    Houston
    11
    Green pool.
    In like three days my pool went from clear pretty water to cloudy and green. We did get some weather and the oak pollen is everywhere. Would just that turn my pool green in three days?
    Jan 2012
    'burbs of Augusta, Georgia
    8,556
    Re: Green pool.
    Seems like it did....but it may well have been working up to it for a long time prior. We can't know for sure without some test results:
    FC
    CC
    pH
    TA
    CH
    CYA
    tell us about your pool, equipment and how you sanitize it. What have you added to the water?
    Yippee
    Skippy's Pool Cooler --> Skippy's New Fountain Our Build --> Our Pool Solved Our Sloping Yard
    Mod Squad tim5055's Avatar
    May 2014
    Franklin, NC
    9,895
    Re: Green pool.
    Insufficient chlorine can allow a pool to harbor a lot of algae that is kind of hidden in plane sight. Many of us describe our pool water as sparkling. When it looses that sparkle, something is happening. I keep mine open all year long and let it go a little this spring as the water started to warm. Without me noticing it went from sparkling, to dull to a little cloudy before I noticed. In all of these conditions it still would have been classified as "clear pretty water" to most folks. I conducted an Overnight Chlorine Loss Test and proved that something was growing in the water as I failed the test. While my SLAM didn't take long, I still needed to eradicate the algae in the water.
    I say all of this because the next step down the road had I not caught it would have been green. So yes, it can go green quickly, but things were growing before that time.
    If it's green it is time to SLAM the pool.
    Support the site
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,999
    Re: Green pool.
    Hi Benjw,
    I moved your thread here from the Coffee Bar just fyi.
    Essential Links:
    Feb 2017
    Houston
    11
    Green pool
    Moderator Note: Please do not start multiple threads on the same topic. I have merged them. Thanks, jblizzle
    Ok I shocked my pool with 4 lbs yesterday. Cloudy and less green today. I vacuumed a good bit up and brushed the pool again. What's next? Should I continually run my pump to filter the algae out?
    40,848
    Re: Green pool.
    We do not recommend putting in random amounts of chemicals in the pool. Why did you add 4 pounds?
    You have yet to post test results, so no one here can tell you what is next beyond: Buy one of the recommended test kits and post up results.
    Mod Squad woodyp's Avatar
    Apr 2010
    East Texas
    10,152
    Re: Green pool.
    You still need to add a signature line to your profile giving us your pool specifics like size, gallons surface and equipment specs and provide us with some GOOD test results from one of our recommended test kits. 4 lbs. of WHAT did you add?
    Feb 2017
    Houston
    11
    Re: Green pool.
    I went to the pool store, had my water tested and went with their recommendations. My test kit didn't come in yet. I put 4 lbs of Chloe brite shock with 2 quarts if phos free and ran my pump for 24 hrs
    40,848
    Re: Green pool.
    Oh, now we see the problem ... you went to Leslie's
    Do yourself a favor and wait for the test kit ... you will save yourself a lot of money.
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,999
    Re: Green pool.
    Hey Ben
    That's alright, we can get you sorted, and what we do is really easy with a little knowledge and some good test results. We can help with Both. With the Green Pool you'll need to SLAM it. It a process of repeated adding of Chlorine to a higher level and keeping it there until the Algae is dead and the pool is clear.
    You need a good test kit on the way first. For a Green Pool the best value is the TF100. The K2006C Is also a good kit, but you'll need extra reagents and the 100XL has them at a much better price per test.
    Next is knowledge. All that is here in Pool School and the first place to go is the ABCs. Eveything you need to know is in PS and there are many around who will enjoy helping you through with any questions.
    For sure you wont need the Phosphate products, so dont add those yet. Take them back or hold the receipt, and perhaps trade for something else. Once we have some reliable numbers from you, we can offer suggestions.
    The links you need are also in my sig line below here:
    Essential Links:
