Results 1 to 15 of 15
Thread: Pool light suggestions
    Mar 2017
    Fountain springs,ca
    11
    I am looking for a good above ground pool light. Anyone have any suggestions? I would prefer to not have a through wall light so I don't have to cut a hole in the wall. Thanks in advance!
    33' round ABG pool
    aluminum wall with steel core
    filled with well water
    Aqua pro 200 sqf cartridge filter system with 2 hp pump
    Aquabot pool rover plus
    Jan 2012
    'burbs of Augusta, Georgia
    8,557
    Skippy's Pool Cooler --> Skippy's New Fountain Our Build --> Our Pool Solved Our Sloping Yard
    CJadamec's Avatar
    Apr 2016
    Quaker Hill, CT
    2,192
    Re: Pool light suggestions
    I have a smartpool nightlighter I got the 50watt version. I put an led replacement bulb in it and it does a nice job lighting up the pool. There is a nighttime shot in the album in my signature.
    Chuck-
    15x30 AG, Pentair Superflo VS, 19" sand filter, TF-100 test kit
    Aqua Comfort ACT750 heat pump / 6x20 ground mount solar panel / DIY automation
    Photos of 2016 Build, Inside Your Breaker Panel, Free Copy of 2017 NEC code
    TFP is AD Free and is funded solely by member support click here to help
    borjis's Avatar
    Aug 2014
    Pacific NW
    2,607
    Quote Originally Posted by YippeeSkippy View Post
    whoa! thanks! I've been looking for something like this for awhile.
    Dolphin E10 Cleaning Robot.
    chayne's Avatar
    May 2016
    Somewhere Around The Red River, Texas
    419
    i am seriously considering purchasing the Intex magnetic pool light.
    https://www.amazon.com/Intex-Pool-Wa...tex+pool+light
    Charles
    Coleman 16'x48"
    Intex 16" pump & Sand filter, Intex Robot Vacuum
    Hayward Wide Mouth Skimmer
    TF-100 Test Kit Magnetic Speed Stirer
    Blake1989's Avatar
    May 2012
    Birmingham, Alabama
    135
    I had the nightlight 100w version years ago. It worked well with my old pool. I'm having trouble finding a light for my bigger pool though.
    TSiGirl's Avatar
    Mar 2013
    Crystal Lake Illinois
    536
    I also have the smartpool nightlighter 50watt. It is very bright.. we bought it in 2014.
    Cornelius 15 Round , Semi Inground, TF-100 Test Kit, Speedstir,
    Hayward 2 Speed Pump Swimpro 150 Cartridge Filter,Intermatic Timer, Hardplumbed,
    Pool Rover S2-50, 2 Maytronics Solara Heating System Panels.
    jeffchap's Avatar
    Jun 2012
    Edmond OK
    1,752
    Quote Originally Posted by chayne View Post
    I've had one of these for years now and it's great, but it won't work for a steel sided pool.
    One weird thing... If I let it dry out it gets dim and yellowish, but after being submerged for a day or two, it returns to normal. It's not the plastic lens. The LEDs actually are dim. I can't figure why it does this, but I only take it out over the winter anyway, so it's not a big deal. I just mention it in the event yours does it too, so you dont think it's broken.
    25000 gallon free-form gunite
    Jandy Stealth pump/CL340 cartridge filter
    Pentair IC40 SWG
    Pentair MasterTemp 250HD heater
    Jandy AquaLink RS automation
    chayne's Avatar
    May 2016
    419
    I appreciate that info. Going to be purchasing this Thursday. So I will have to remember that if it ever happens
    Charles
    Coleman 16'x48"
    rbinn's Avatar
    May 2015
    Nanaimo BC
    85
    I have the Intex Magnetic. Its bullet proof...I put a GFI plug on my Suntouch that is set up to go on and off automatically. Love pool season!
    9 x 18 Hydro Force AGP, Aqua Pro AP ASFAL 75 pump and sand filter, Hayward Skimmer, Raypak 106A propane heater, Sunquest Solar Panels, Pentair Rainbow test kit.
    RoxxW's Avatar
    Dec 2016
    Poquoson, VA
    120
    Question Re: Pool light suggestions
    Quote Originally Posted by CJadamec View Post
    How long would you estimate the power cord??? The manual on the Smartpool site does not give a length. My GFCI plug is approx. 10' max away from the pool wall.
    I see your photo with the light on. I would venture to say a 100 watt would really light the pool up?? Where did you find the LED bulb for it?
    I just finished a DIY 18x33 Oval. See my build here for my GFCI location:
    https://drive.google.com/drive/folders/0B8DY5EnJk5XMcnF0aWtQV3BHVkk?usp=sharing
    Yardmore 18'x33'x54" Saltwater LX Oval Pool Semi Inground 18K Gal, Hayward XStream 150 Cartridge Filter System 1.5-HP Power-Flo Pump, Hayward Aqua Trol RJ Salt Chlorine Generator System, Hayward Thru-Wall Skimmer & Return Fitting, SmartPool PT7i Inground Climbing Robotic Pool Cleaner, TF-100 Test Kit XL Option, https://drive.google.com/drive/folde...kk?usp=sharing
    Sicklerville, NJ
    5
    Quote Originally Posted by RoxxW View Post
    Walmart lists the cord length at 28 feet.
    -Chris
    24'x52" Round Above Ground Pool - 1.5HP Hayward Power Flo LX Pump - Dream Line High Rate Sand Filter - Intex SWG
    CJadamec's Avatar
    Apr 2016
    Quaker Hill, CT
    2,192
    Nice job on the pool so far.
    The cord from the transformer to the light is about 28'. The cord from the transformer to the plug is about 18". The transformer is where the on/off switch is. So you will want to plug it in in a spot that is convenient to get to at night when you want to turn the light on and off.
    I forgot exactly which bulb I ended up getting but it is a bi-pin base 12V bulb it was pretty easy to find on amazon from what I remember.
    Chuck-
    RoxxW's Avatar
    Dec 2016
    Poquoson, VA
    120
    Thanks. It was a bear of a job to install for a first timer. I will opt for an installer next time. Getting to old to build stuff like that!
    One last question even though I think this is the light I need. Can the on/off switch be reached from inside the pool?
    CJadamec's Avatar
    Apr 2016
    Quaker Hill, CT
    2,192
    The on/off switch is built into the light transformer which has a very short plug to get plugged into an outlet. The Long 28 foot cord is the low voltage side going to the light. The only way you will be able to reach the switch is if you have an outlet within arms reach of the pool which I don't exactly recommend.
    Chuck-
