Thread: I have an easy touch pentair refill spa
    Mar 2017
    Murrieta, CA
    1
    Unhappy I have an easy touch pentair refill spa
    I tried to heat up my spa but instead it drained it. I tried to fill it by putting it into service and putting the pump to fill. But nothing is happening. What am I doing wrong and how can I fix it???
    Mod Squad Jimrahbe's Avatar
    Jul 2014
    Bedford, TX
    9,265
    Re: I have an easy touch pentair refill spa
    Meagan,
    Welcome to TFP... A Great resource for all your pool questions...
    I assume you have automated valves that automatically move to select either the pool or spa.
    I suggest you put the EasyTouch back to auto and watch the automated valves. If they move, wait until they stop.
    Then, select the spa mode and watch the valves. Both the Intake and Return valves should move about 180 degrees.
    My guess is that one of your valves is not moving and is most likely bad.
    Let us know how this test turns out,
    Thanks for posting,
    Mar 2015
    Sugar Land , TX
    446
    This might help with switch position
    http://www.pentairpool.com/pdfs/ValveActuator.pdf
    8500 gallon IG Pebble Sheen with Spa. 3hp Pentair VS Intelliflo ( pool ), 3/4 hp WhisperFlo ( water feature ),Pentair Racer, 400K Pentair heater, Pentair 500sqft Cartridge filter, EasyTouch 8, Stenner 45mp2 15gallon wired to ET8
