Thread: Whats the best vacuum side pool cleaner?
    Ones that operate using suction created by the pool pump.
    I've been using Hayward Aquaray for about 10 years cause their cheap but would like to try something else.
    20x40 Vinyl Lined Inground
    Central GA
    Chem: Bleach/Borax/Chlorine Tablets
    Apr 2016
    Orlando FL
    48
    Re: Whats the best vacuum side pool cleaner?
    The "Pentair Kreepy Krauly Great White" is very good. Not many moving parts and last a long time. I had one from 2008 to about 2012 (stayed in the water 24/7), then I replaced it with poolvergnuegen (had good reviews) but that one fell apart in 3 years, so I went back to the Great White. It still works although now my underground pipe for the pool's vacuum port is clogged and I cant get it clear, so I switched to pressure side cleaner. I would suggest that you also a "leaf strainer/filter" to the vacuum hose.
    20K gal In-ground pool w/spa; IntelliControl, IntelliChlor, IntelliPH (Acid-Injector), SAM/SAL lights, Pentair FNS60Plus filter, two 1.0 HP WhiperFlow pumps, Jandy/Compool auto-valves, RayPak Heatpump, Jandy Gas heater
    Divin Dave's Avatar
    Oct 2013
    Longview, Texas
    5,126
    Several TFPers have The Pool Cleaner. Never heard any negative comments about these things. Here is a link to what they look like.
    Hayward The Pool Cleaner 2 Wheel Cleaner - 896584000-013 - INYOPools.com
    There are a few different models of them, so do your homework and pick which is best for you.
    Divin Dave,
    Apr 2014
    Brookfield, CT
    18
    I've had a 4 wheel suction side The Pool Cleaner for four years. I would recommend it highly. Never had a problem with it, never had to replace anything. Cleans quickly and thoroughly.
    21' x 41' vinyl in ground pool, 26500 gal. 1 hp Hayward pump, 4 wheel suction side The Pool Cleaner, Hayward EC-75 DE filter, Hayward SUMXL 140 heat pump, TF100 test kit with stirrer.
    I've hesitated on placing order for the Pool Cleaner for a couple of reasons. 1. All the ones I see on sale say the wheels are for concrete pools and for vinyl liners you need to change the wheels. Can't seem to find one that comes with the vinyl wheels already on it. 2. Hayward bought this company and have introduced the similar Aquanaut 200 and 400. Would that be an upgrade over the Pool Cleaners? Did they discontinue the Pool Cleaner and are just selling off inventory?
    Central GA
