Results 1 to 14 of 14
Thread: Just filled it up...bubbler off center...
    Feb 2017
    Frisco, TX
    7
    So we just finished filling it up and the equipment went on today....only to discover that the spa bubbler is a foot or two off center. They centered the bubbler on the foot space in the spa instead of the center of the square spa. There are three ledges to sit at, instead of four, so the foot space is off to one side. From the skinny end of the pool, it's no big deal..but the pool is rarely viewed from those sides. From the house, it's very clearly off center.
    Looking at the blueprints...can't really tell where it is. Just seems really strange. I guess I could simply never run the spa bubbler... What do you guys think? Does it look super weird? Would you just leave it off all the time? Should I just try and forget about it?
    Really happy with how everything else turned out...this just seems like an obvious oversight.
    Mod Squad kimkats's Avatar
    Jul 2012
    Tallahassee, FL
    33,963
    Re: Just filled it up...bubbler off center...
    I like it there! I would run it any time I wanted to show off the pool and that pool is worth showing off!
    Kim
    Mod Squad Jimrahbe's Avatar
    Jul 2014
    Bedford, TX
    9,292
    P,
    You know it is off, but I doubt anyone else will even notice.
    After the new wears off, you'll find that running a bunch of water features will cause your pH to increase more than you will want anyway...
    Thanks for posting, and a beautiful pool, no matter where the bubbler is.
    Jul 2016
    Holly Springs, NC
    87
    It would drive me crazy! I wouldn't run it for that simple reason.
    bmoreswim's Avatar
    Jul 2012
    Central MD
    4,152
    Pools are like people. We all have our issues.
    18'x38' Rectangle (3'-8 1/2' deep w/ diving board) - 27K gal. w/ gray plaster
    Hayward equipment (cartridge filter, 2-speed pump, SWCG, automation) View Our Build
    Coverstar automatic pool cover | StoneMakers concrete retaining wall and decking | Merlin SmartMesh winter safety cover
    Spring 2013 Build | Dolphin Active 20 robot cleaner | Support TFP!
    Feb 2017
    Frisco, TX
    7
    Quote Originally Posted by ponygirl View Post
    It would drive me crazy! I wouldn't ruffn it for that simple reason.
    I'm leaning towards this as the best option here. We'd still have the other bubbler and then we'd get the cool glass like effect of the infinity spa which is awesome in its own right.
    Can't wait to see this baby in the sunlight. Super excited about how the colors came together in the end. We did yacht club blue jewelscapes which seems to go really nicely with the tile we picked.
    Mar 2016
    Las Vegas, NV
    182
    Just my opinion, but your pool looks awesome. I love blue pools, and this one is definitely something to be proud of! Did you say there is an issue with a bubbler somewhere? I looked twice, and all I see is a picture perfect pool.
    But, in all seriousness, it's your money, and if you don't like it, talk to the builder, and see if there's any way to fix it. Then you could make the decision that works best for you, whether to live with it, or fix it.
    Jul 2016
    Prosper, TX
    20
    Wouldn't the bubbler have required an extension to actually break the surface from the bottom of the spa? I'm thinking create an extension using two 90 degree elbows and three straight pieces to make it break the surface from the center.
    Sep 2015
    Las vegas nv
    96
    Quote Originally Posted by bard View Post
    My thoughts exactly
    10k Gal, IG Gunite, 10' X 28' X 5.5', Quartz, Hayward Ecostar VS 2HP, Hayward 325 sq ft, 2" plumbing, 2 24" sheer decent, 2 bubblers in tanning ledge, Hayward LED, Build Date Dec. 2015. auto pool cleaner suction side. Suntrek Solar panels, Taylor K-2006
    Feb 2017
    Frisco, TX
    7
    That is correct. They told us that the extension can be removed and put back in as we need to (as long as heater isn't on, cause of the metal expanding I guess) since we were concerned about there being a big metal bar in the middle of the spa when we were trying to sit in it. Seemed awkward.
    How would we go about having something like that made? Makes sense..what you're saying.
    Mar 2016
    McKinney, TX
    176
    Quote Originally Posted by princesshockey View Post
    I would tell your builder to make it-- pretty simple, a pvc pipe with the 90 degree elbows to make the 'fountain' in the middle. Keep the straight one too just in case. Our spa bubbler is just a straight pvc pipe that we take out when using the spa. The pool is beautiful! But if the bubbler is off center I can see how it might bother you.
    17K gallon, 18x40, 107 perimeter, 550 sq ft gunite inground pool with raised spa. 3.5 ft. - 5.0 ft. - 4.0 ft depth. Pentair equipment. DE filter. English Walnut travertine paver decking, lueders limestone coping. Wet Edge Primera Stone Sapphire Treasure plaster.
    Mar 2011
    Scottsdale, AZ
    406
    Why would you put a bubbler in an infinity spa. You are spoiling what was created. Get rid of it.
    Mar 2016
    McKinney, TX
    176
    Quote Originally Posted by Just-a-PB View Post
    True! duh maybe that's why it looked off!!
    Feb 2017
    Frisco, TX
    7
    Haha...fair enough! We barely recall the conversation with our designer at this point..but I do remember us talking about how weird it would be to have a pole (extension) in the middle of the spa, so I feel like we talked about not having it but somehow it wound up going in.
