Thread: Filtrite 4 in 1 pool test kit
    Feb 2017
    Australia
    20
    Hi there
    Here in Oz, do people rate the Filtrite 4 in 1 test kit available from clark rubber?
    23000 litre salt chlorinated pool, fibreglass in ground with 1500litre spa
    Dec 2015
    Hawera, Taranaki, New Zealand
    443
    Re: Filtrite 4 in 1 pool test kit
    G'day Aussie
    This test kit has an FC test, a ph test, a TA test and an acid demand test, cost of $33.75
    The FC test will only test up to 5 FC, which is not high enough
    You also do not have a CYA test (crucial) or a calcium test (not as crucial for you as you have fibreglass not plaster, but still need to know this)
    I would just go ahead and order a kit from Clear choice. Has all the tests you need, also comes with standards so you can check your testing. Should last you a full season of testing and refills are available. Service and quick delivery from these guys too. My last order was on a Saturday and I got the test on a Thursday.
    For you to get the salt water version its $158. Money well spent imho
    https://clearchoicelabs.com.au
    6000 gal, AG vinyl, Intex ultra frame 16ft, 1200 Gallon Sand Filter, DIY Solar, Clear Choice Labs Testing Kit
    Feb 2017
    Australia
    20
    Quote Originally Posted by Caco View Post
    G'day Aussie
    Thanks for the link - cheers
    needsajet's Avatar
    Jan 2016
    Sydney, NSW, Australia
    4,496
    Welcome to TFP! Good to have you here
    The 4in1 is good value and won't go to waste if you already have it, but +1 to Caco's review and recommendation.
    Another drawback to the 4in1 is that you can't do an overnight chlorine loss test (OCLT), which can be a crucial part of TFPC.
    The 4in1 is fine for pH, acid demand, and TA. It's adequate to read "around 1 ppm FC", "around 2-5 ppm FC", and "solid 5 or more ppm FC"
    12k IG salt; glass beads in plaster; K-2006C, K-1766, K-1106 and CCL test kits; Pentair Eco800 1.2HP VS; Zodiac SWCG 1.3 lb/day (25 g/hr); 25" filter recycled glass; OKU solar panels; 1/2 HP solar pump; Rebel (Warrior) pool cleaner; FlowViz; Other family pools 10K SWCG and 15K on liquid; PoolMath app subscriber; | Read Before Posting to get the best possible advice | ... and this helped me a lot!: TFPC for Beginners
