Pucks either have CYA (stabilizer) or CH (calcium hardness) to help bind the chlorine in to the solid form. The person that finds a way to make pucks without anything "harmful" will make a fortune!
You can do Reverse Osmosis that will remove CYA and CH. It is $$$ but in places with water restrictions it is an option. Not many places have it available.
I don't see it as being stupid. It is more not knowing. The pool industries are just now starting to know about and accept the CYA/FC ratio. There are many (most) that do not understand it OR chose to ignore it because it hits their bottom line $$.
You go to the pool store thinking they know what is best for your pool. You have them test your water and they tell you you need to buy this and that so your pool will be all set. You go back the next week and they test and say oh now you need that and this. Just the opposite of they said last week
The pool service comes once a week so they have to hit it so hard it is not safe to hope the FC makes it until the next week. Just think about the people who don't have their own test kit and let their kids and family swim with the FC so high :sad:
I am glad both of you found TFP. You will not believe how your water looks when I am done with it!
Sprangdog-I look forward to seeing your own thread when you go to open. If I do not see it right away make sure to PM me so I can help you out.
Newton, you are on the right track. We are close to getting everything where it should be. I can't wait to see just how high your CYA is No matter how high it ends up you can go ahead and start your 64% drain and refill as we KNOW that needs to be done. The only question is how many times.
Kim
Kim
I was thinking since I need to drain a significant amount of water
Would it be a good idea to go ahead and do a full drain and acid wash the pool (I have a feeling the pebble is probably coated with the Calcium since the hardness is so high)
What are your thoughts ?
Then do a fresh fill and start this baby off the right way
